FlDart360
Hey guys,
Looking for some clarification on what works right the first time for water pump replacement on my 360LA. Specifically with gasket and bolt sealing.
1. Permatex instructions say only lay a bead down on one side of the gasket? Is that what works best?
2. Are only 4 bolts penetrating water passages and need sealing on the threads?
3. Is it ok to us the same Permatex on the gasket and bolt threads?
4. I was given two type of Permatex is one better than the other?
5. The pump is a stock replacement if that make a difference in any of this.
Thanks.
Thanks.
