octanejunkie
Mopar Padawan
Is there a 2 groove water pump pulley for SB mopar, specifically the 318 V8?
Should be the same for 70-up 318-360 with a/c.
what do ya need a double pulley on the water pump for??
a/c cars had single pulleys on the water pump. 2 belts went around the crank,alt and a/c compressor on factory 70-up small blocks...
I don't like the belt routing on my 318, not should what it should be, but I was going to match my SBC belt routing - or go serpentine for $$$
Currently my setup is as follows:
Pulleys
-triple crank pulley with overdrive (reduced) outer pulley
-single wp pulley
-double alt pulley
-single large ps pulley
Belts
-ALT: belt on middle crank pulley to outer alt pulley (runs under wp)
-PS: belt on outer (reduced) crank pulley to wp pulley to ps pump pulley
You can vaguely see the ALT belt path in this pic...
The setup on my SBC in my '59 runs the alt belt over the wp too, hence the need for double pulley on the WP, but I haven't installed my AC yet... Here is a pic of the belts on my truck
The AC belt will run over the wp and on the middle crank pulley, not sure why the compressor has a double pulley, options I guess...
Back to my Scamp, I was thinking about running the ALT belt over the wp rather than under it, so something turns my wp in case my ps belt breaks
I guess the question I should have asked is: what is the proper belt routing for my '71 Scamp with AC? Though right now I don't have the AC compressor or brackets...
THE A/C And alternator use double belts and dont touch the water pump..
your power steering belt should not be on the water pump.
abodyjoe - thanks for posting the pic. According to that pic the AC and ALT bypass the WP completely and only the PS pump drives the water pump. I doubt the brackets on my car are correct at all actually, there are washers and all sorts of crap that someone (read previous owner) threw in there but I know it is not correct - would love to get a look at the correct pulleys - but I HATE that AC compressor placement already...
depending on your crank pulley the bigger dia. of the chevy pulley may cause it to hit the crank pulley.
it would all work alot better if ya scrounged up the proper pulleys and brackets. they aren't usually too expensive
