ways to speed up 3rd member swap
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
reusing the fluid and filling it through the axle tube. (one jack stand tilted)
I've got right stuff gasket maker on the housing side of the gasket and thick grease on the 3rd member side. I also installed a drain plug on the housing. Planning on building the jack pictured above. hopefully be able to swap diffs in less than 20 min.
