afbill
FABO World Ambassador
Be carefull what you use it on. WD-40 is a BIG no-no in the aviation industry. It can trap water which will cause corrosion. Corrosion is the bane of all aircraft and A-bodies
I use WD-40 to remove burnt rubber off the back of my 1/4 panels...squeaky clean.:glasses7:
Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you.
Hmmmsome of these sound like bullshit. i have lived in new york my entire life and have never heard of the state putting wd-40 on the statue of liberty.
i also dont think fish oil is in wd-40. look at their ingredient list. its in section 3.
http://www.wd40company.com/files/pdf/msds-wd494716385.pdf
X2!I can't speak for most of those uses, but if you're using WD for what most do, ie lubing hinges or freeing rusty bolts, you're wasting your time. Get some PB'laster instead.
Really? Interesting....................Spray on spongee shoes for a better grip on the ice
Grant
Too bad it doesn't repell bullshit! Think of the many uses! Just sayin'
I sprayed some into a chevy distributor(window type) while it was running to dry it out. Bad idea. It blew the cap off the distributor.
Smells so good too!!Has that manly "mechanic" scent,kinda like GOOP hand cleaner =)
