Sounds like you nailed it!:thumbup::thumbup::thumbup::thumbup:just finished timing my car.... (NOOB) but here is what i did...
went to SEARS bought a 60 dollar gun.
got home let it cool down, loosened the distributor.
disconnected the vacuum advance and plugged them both.
set the timing at 16-17. hooked the vacuum back on and checked timing at 2500/3000 set at around 37-38....
tuned the fuel to air ratio a bit.... runs way better..!
but something could be wrong since i havent done this before...
someone tell me if i did this right, my first time. haha
Cool...(pun intended)Almost finished with the reassembly![]()
Forgot 1 dash panel, so have to drop the column againops:
Well it has been a while but just finished up painting and cleaning up Grill....
I know its not right but I like it, that way....
One of kind I would say.
New Grill Installed
Trying to fix an exhaust leak on the Dart Wagon....
Found one of the bolt hole flanges broken off almost 180° around where it cannot support a bolt and washer any more...
Then found an open hole in the collector area of the flange that looks like it should have an O2 sensor in it, but it may have come out at some time. this exhaust used to be quiet(er)... Dual exhaust with 2" pipes all the way through to Dynomax 2" super turbo mufflers on a 225 slant...
The areas of interest:
