D downsr Well-Known Member Joined Dec 17, 2011 Messages 885 Reaction score 85 Location waverly ohio May 3, 2017 #1 What carb gasket for small block rpm air gap dual plane with a 750 holley. Intake came with a gasket that went across the divider on intake.Is everyone using a 4 hole or open gasket
Steven190 Well-Known Member Joined Jan 13, 2012 Messages 1,250 Reaction score 655 Location Omaha May 3, 2017 #2 Mostly use the large open hole. Use the 4 hole if the manifold has the dividers for the separate holes
rumblefish360 I have escaped the EVIL Empire State! FABO Gold Member Joined Jun 21, 2005 Messages 49,463 Reaction score 23,301 Location Florida May 3, 2017 #3 It's not really going this make a difference. Thickness is another story. Ether for heat insulating issues or a possible height issue.
mopowers Well-Known Member Joined Feb 15, 2006 Messages 8,599 Reaction score 4,806 Location West Sacramento, CA May 3, 2017 #4 Mr gasket 54 is what I use. They work well.
nm9stheham Well-Known Member Joined Dec 20, 2013 Messages 12,087 Reaction score 4,283 Location Waynesboro, VA May 3, 2017 #5 Mr Gasket 55 is the large hole one with all the dividers.
