What fan to use
joemoy29
NJ
I am in the final stages of my 340 build and my old 318 had a "mechanical fan" (not sure if that's is correct term) should I get one with a clutch? It's a 70 dart
Mancini sells new clutch fans, but you need to make sure that you have enough room to the radiator or it will hit or be too close...
Viscous / Resto Fan Packages
There is a low profile clutch that is about 1/2" or so shorter....
I have a 74 Duster with factory AC and the stock 26" rad and shroud. A stock clutch fan from an 85 Dodge truck fit and works perfectly. It's an 18" 5 blade fan.
Cley
