What front disc are these?
71valiant
Make fast, break, repeat.
Columbus, Indiana
I'm in the process of bleeding brakes....kinda curious what this setup is. It's on a 67 Valiant.
And shouldn't my inner pad click into the caliper piston? Because it doesn't. It's just floating there.....
Those are the "Slider" type single piston caliper.
Most likely 73-76 A Body disc brakes.
But without me looking at a picture of your actual spindle (knuckle) they might even be off an Aspen, Volare, or other body style car.
No, brake pads don't "clip" into the caliper piston on a brake system such as what you have.
Ok. Thanks. I was assuming they were a stock style. I've got a 73+ k member. So that's what I figured. The no clipping in the piston threw me. Lol
Those pads sometimes need "adjusted." Read the 73 shop manual which you can download free at MyMopar.
