I got this with some parts. It looks like a Sure Grip of some sort, and in less than bolt in condition. Can it be rebuilt?
It's fine.If that's what it is, is that good or bad?
Open it up to see if the cone has bottomed out.
The unit does not have clutches. It has two threaded cones that lock into the inner case sides and that causes both axles to lock together, but still allows enough slippage to go around a turn. They are pretty good when in good condition. They are not rebuildable "by the book" but I have reworked hundreds through the years to make them work like new again. I just got through with one for a member here and he is sending me another.
Good eye there Roy. I never noticed that till you pointed it outIt appears as if the cross shaft has spun in the case halves, If so it needs more than the cones cut down.
You charge a flat fee for that, or are you stabbin' a time clock?
If it can be fixed, will this work in ANY 8 3/4 center section with any gear?
