Baxter61
For a given motor, what kills them more; rpm or hp? Discuss
Yep..... And also what role does harmonics/balance play in the long term stress on the bolts?Also when the other piston fires it jerks down on the rod so HP is also a devil in this game.My guess is all of it.
The nut behind the wheel and on the pedal!!!
Hey Rob, so how does the motor go when some dumbass steps on the rev pedal?I can answer that very simply without all the "harmonics" and "distortion" and all the high brow BS. Here we go. You ready? What absolutey kills the HELL outta rod bolts are dumbasses. Shall I explain? Allow me. Next time you're at the races.....or on the street and hear some FOOL sittin still in his car and repeatedly revvin the motor like this....WAAAAA.........WAAAAAA .......WAAAAAA........WAAAAAA THAT's what kills rod bolts. Plain and simple. Everytime an engine is free revved, the rod bolts stretch ever so slightly and the big end of the rod elongates and then goes back. That's why when people use used rod bolts, I always shake my head. I mean, 50-75 bucks and you couldda had good ones. So, what kills rod bolts?
DUMBASSES.
Here endeth the lesson. lol
So how does it again???voo--bah!!! VOOOOO---BAHHHHHH!!!! VOOOOOO--eefffin'kabooom!!!
Expanding on Brian's post - Any bolt has a certain expected life, based on material, manufacture, and load. It's designed to work with a certain amount of life span given the expected load.In terms of a rod bolt, the worst things for it are "extra" harmonics and improper install/preloading. The free revving doesnt hurt anything as long as the engine is correctly done. If you think otherwise, go find the video of the Indy engine playing "We Are the Champions" by alternating rpms...lol. But, if the bolt is nicked during install, or the threads are not lubed with the right stuff, and it's not torqued to he preload the manufacturer designed in, then the lifespan has been reduced. How much depends on the amount of "wrong" and the usage. Harmonics kill and wound a lot of otherwise good engines.
if you keep hitting the rev limiter, that hurts parts. The rev limiter should be set high enough that you never hit it but there just in case of driveline breakage
...........being an idiot.............
Hmmm, well why does rev limiters have a dirty name in racing ? Go on speedtalk, many of those engines builders swear rev limits hurt engines if they are used too often
