11 X 3" rear brakes came on many C-bodies, especially wagons, but, also police/taxi and tow package cars. The backing plates must match the shoes they're supposed to have or the shoe will be cocked, and initially only wear on either the inner or outer edge depending on the mismatch. Take a pair of backing plates with you to the parts store and try each option to see how they fit. the shoe surface must be 90 degrees from the backing plate so the shoe contacts the drum evenly. Then you can get the correct hardware kit and drums to match. If you just have bare backing plates, you may have trouble getting all the hardware for some applications. If you have a pair for the 11 X 2 1/2" brakes. I'd use those. They're the easiest to get parts for. The 11 X 2" are probably the next easiest as they use those on the 1/2 ton pickups quite a bit. The 11 X 3" might be overkill for some applications, but, will work on lighter cars if you use an adjustable proportioning valve. The Imperial had an 11 X 3 rear brake too, but, also a unique backing plate that was different than the standard C-body one. It might work if you can find all the Imperial parts to go with it. They had a different bolt pattern wheel, so, drums might be an issue.
