What sure grip is this?
Sedanman
67-9 Valiant specialist
chicago Il
I got this from a buddy but he didn't know much about it other than being 4:10 gears for a 489 case and it doesn't look liker any factory unit but is std mopar spline.
It also appears to be an 8.250.
BTW, Auburn cone sure-grips are not the same as the Borg Warner cone sure-grips installed in OEM '69-'74 8.75" rearends.
I need to see if I can get parts for it. The cross shaft is damaged and the insert may need replacing if this isn't what it's supposed to look like. There is a drift pin missing on one side where the axle contacts it. The one side twists off to take the sure grip apart but there is a pin in the keyway and I can't figure out how the pin comes out.
