Thanks for the picture Jpar. Unfortunately that won't work for me.
With my springs being moved into the frame I can't use a spacer but I could weld up my holes and re-drill a new one back a half inch.
I actually ordered my driveshaft a hair longer then stock so I checked and I can definitely move the axle back a half inch or even 3/4 of an inch without adversely effecting the driveshaft yolk.
Just drill a hole further back. Plenty or room and meat in that bracket.
Question for you guys, I also have a similar setup, Dana 60 3.73 gears, 2.64 first gear.
Gear Ratios:
1st 2.64 : 1
2nd 1.92 : 1
3rd 1.40 : 1
4th 1.00 : 1
5th 0.70 : 1
I currently have a Borg & beck 3 finger pressure plate: RAM Powergrip Clutch Kits 98773, But I need to update to an 18 spline clutch disc... what would you recommend
the one that's almost $2,000 bucks?? I'm sure it's an excellent drag racing clutch, but can that thing be used on the street, and for how long? As for adjusting that thing, I wouldn't even know where to start. lol. That's definitely above my pay grade.I think there is a unit for sale right here in FABO and it had the 18 spline disc and a spare disc as well. Seems he had a pretty decent price on it as well.
Search through the for sale ads here. I don't think it sold yet.
That's the clutch you want.
Okay thank you. I will definitely have to think about it. That's s large sum.Yes, that's the one. And yes, you can use it on the street. As for tuning...it's not that hard. I had about 18,000 miles on my last disc and I don't know how many passes. If you are even a fair driver the disc will go a good bit.
How can you remember that long ago?!?I had about 18,000 miles on my last disc and I don't know how many passes.
I cannot verify his track time as I know of no track time to verify whatsoever!As jpar about that, as he can verify my lack of track time.
look it up, YR is a legend in the Yakima valley. lolI cannot verify his track time as I know of no track time to verify whatsoever!
And where's the legend of the Yakima Valley?! LOLSo...OP, what did you end up running?
?look it up, YR is a legend in the Yakima valley. lol
Yeah I think that there might stick?I always thot the legend of Yakima valley was a skunk ape !!
Not saying he stinks !!! LOLI always thot the legend of Yakima valley was a skunk ape !!
