DartSport340
- Joined
- Apr 10, 2008
- Messages
- 199
- Reaction score
- 1
Probably a future project as this year is full up but I like to get my parts and stuff a but at a time and have everything on hand for when im ready to do a project. when we first got it the original cam was pulled and replaced with the 284/484 MP grind..with the lower 8-8.5 comp ratio I think the car has it just didnt work right..pretty lumpy, sounded great but power brake feel sucked just not good with a low compression set up. Still have the cam and lifters on a shelf. I was just "too much" cam for what I have in the rest of the car/current set up...that came out and in went one of the Summit cruiser type grinds thats very stock but cruises around much better and brakes work great . I have no plan to touch the heads or anything like that till i need a full rebuild in the future so its gonna be im guessing 8-8.5 comp ratio..
Car as it sits currently
1973 Dart Sport 340
340 engine with a stockish cam its the Summit Mopar grind and its very docile 204/214 duration at 0.050, 420/442 lift
It will by then have the stock intake manifold and most likely a TQ by Demon Sizzler on it
heads are the Aerohead heads I believe J heads?? I think the $499 ones with these specs??
[FONT=Arial, Helvetica, sans-serif][FONT=Arial,Helvetica,sans-serif]340-360[/FONT]
[/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Verdana,Arial,Helvetica,sans-serif]1968-1987 340-360 A-Engine Assem., 1.88 or 2.02X1.60 Stainless Valves, 67-70cc Open Chamber Design, .509" Lift Springs, 160cc Intake Port Volume[/FONT]
[/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Verdana,Arial,Helvetica,sans-serif]$499.00[/FONT]
pair
[/FONT]
727 Tranny thats stock from what I can tell same with converter and 3.21 8.25 rear end
1. Can you recommend a bit better cam that will work well with my lower compression ratio give me some more power but still let me keep the power brakes working right and play nice with everything else??
OR
Till I rebuild it someday should I just leave it alone have fun and enjoy(meaning a new cam wont do much with the rest of the combo)
I dont want to spend money just to spend money or change things just to change them if its not really gonna do too much. Im willing to just leave it but just wanted to know if there was anything better out there or if I should just "hold off" till I rebuild everything and can mill the heads and do all the stuff I want to do to raise the comp ratio to closer to 9-9.5 to 1.
1973 Dart Sport 340
[/FONT]
[/FONT]
pair
[/FONT]
OR
