Wheel question
Larryss
Berea, ky
I have a 75 Plymouth duster with 7 1/4 rearend and it has original 14 inch wheels on it.its the 5X4.00 sbp. Can I put 15 inch wheels on it.
sure
US indy still makes 15s in 5X4
15X7s up front, 15X8s out back
I put duster. It's a 75 Plymouth valiant
OK, that does make a difference, the valiant does not have the same room in the back as the 75 duster does
now, you can still fit 15X7s in the back but im not sure about the 15x8s
that is something that may need to be measured
Aftermarket only. The factory did not make 5x4 bolt pattern in 15 inch sizes, in case that is what you were wondering.
Wheel Vintiques has a selection of SBP in 15", Rallies and Cop wheels if I remember right. If Steelies are on the list of things to do that is.
