SwingerMan
Man what a frustating few days. I bought a set of Yukon 4 1/2" bolt axles, 73 front disc setup and 11" rear drums to swap onto my 69 Dart. I also bought 15X7 factory steelies and 245/60/15's to run out back after reading a lot of posts here I thought I was good to go. Got one axle installed and went to put the wheel/tire on and it wouldn't go in with the drum installed. Took the drum off and it barely squeezed in there you could barely wedge a sheet of paper between the tire and wheel well....something ain't right. I have about an inch toward the leaf of space so I was thinking the off set of the wheel isn't right. Are all 15x7 steelies the same offset no matter what year or model they came off of? I believe these were off a Ram Charger.
We came up with a back spacing of 4 3/16" on the 15X7 steelie is this correct? Looks like moving the wheel offset approx 3/4" towards the spring will make it work. It will make the total back spacing close to 5" does this sound right?
We were wondering if I might have a b-body 8 3/4 under there but the Yukon axles measure 27 1/2" the same as the factory axles we pulled is that the correct measurement for a-bod axles?
I am hoping a different offset wheel will fix it up any input is much appreciated.
