Wheel size choice and fit
mopars
Toronto, On
Hey
I"m really into the american racing torq-thrust 2 wheel for my 67 dart, but i'm not sure on the sizing of what I can put on? Should i run with 17 and anyone know is these would work (i know they should work in the rear but im not sure about in the front) or should i run the 15 inche wheels all the way around or a 15 up front and a 16 out back?
Heres the link to the wheels
http://www.americanracing.com/browse_all.asp
Page 2 Series 505
IF anyones got some pic of a dart with 17 inch. wheels,that would be awesome!
thanks!
at least a 15..... and if you go 17 with a 4.5 bolt pattern, you can use the
"Bullit" Mustang wheel (keep the cost down) with a B body rear end housing
and i think you might not have to move the springs in(saving labor)...73&up (or RMS) upper control arms and F body spindles and brake stuff..same "Bullit"
wheel should fit on the front (maybe a .25 spacer?) with some sway bars front and rear, you'd have a beginner G car, or whatever they call'em...
Any size wheel diameter wheel can work 15,16,17,18+. It depends on the tire size, wheel backspacing and the look you like.
