I got some reproduction 68 side marker lights a few years ago (can’t remember source) but my project is only just now getting around to that stage. As soon as I pull the headlight switch-pop, there goes a fuse.
I have rewired a ton of stuff, changed some stuff, and added stuff, so I assumed it was in my work somewhere. Turns out to be shitty sockets for the side markers. The contact for the bulb + is inside a metal spring inside the metal housing. As soon as I disconnected the side markers, no problems. Chinese crap!
I can reuse the original 2 in the trunk, but the original fronts were pretty well trashed.
I need 2 sockets for the 1895 bulb, 1968 self grounding side marker lights and sockets,
I also need sockets for the tail/brake light, the ones I ordered for those looked pretty decent in the description, but are just as crappy as the sockets on the side lights.
If nobody knows a source for good sockets , I’ll probably post in the wanted section
