cdwmotorsports Well-Known Member Joined May 22, 2004 Messages 290 Reaction score 50 Location Martinsville , IN Oct 28, 2019 #1 My front “bowl” on my master cylinder is empty does it feed fronts or rears? The pictured master cylinder is a 72 Demon that has a stock proportioning valve in it.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,069 Reaction score 33,346 Location Idaho Oct 28, 2019 #2 Front master should be routed to rear brakes
dukeboy440 FABO Gold Member FABO Gold Member Joined Jan 19, 2007 Messages 57,246 Reaction score 34,485 Location No Oct 28, 2019 #3 Generally speaking if it’s front disc, rear drum, the front goes to the rear, the larger rear reservoir goes to the front discs.
cdwmotorsports Well-Known Member Joined May 22, 2004 Messages 290 Reaction score 50 Location Martinsville , IN Oct 28, 2019 #4 Thanks guys. That’s what I thought but it’s been a long time and it was difficult to see how the lines went after the proportioning valve. confirms where the wet on the tires was coming from too. Good thing I have spare wheel cylinders sitting here.
