dibbons Well-Known Member Joined Nov 6, 2009 Messages 5,744 Reaction score 3,829 Location La Paz, B.C.S., Mexico Oct 10, 2022 #1 The '65 Formula S power booster failed for the second time, decided to finally upgrade. What aftermarket source would be best? Thank you.
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,700 Reaction score 11,767 Location Wisconsin Oct 10, 2022 #2 Which are you looking for? The title says m/c, text says booster?
dibbons Well-Known Member Joined Nov 6, 2009 Messages 5,744 Reaction score 3,829 Location La Paz, B.C.S., Mexico Oct 10, 2022 #3 Everything needed to convert from single master cylinder w/factory power to dual master cylinder with power.
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 87,790 Reaction score 68,510 Location Hoppyworld, PA Oct 10, 2022 #4 Dr diff
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,700 Reaction score 11,767 Location Wisconsin Oct 10, 2022 #5 Front disc or four wheel drum?
Heywodja The Heartbeat Stops Here FABO Gold Member Joined Aug 16, 2014 Messages 1,548 Reaction score 1,370 Location Texas Oct 10, 2022 #6 @DoctorDiff
dibbons Well-Known Member Joined Nov 6, 2009 Messages 5,744 Reaction score 3,829 Location La Paz, B.C.S., Mexico Oct 10, 2022 #7 Four factor drums all around.
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,700 Reaction score 11,767 Location Wisconsin Oct 10, 2022 #8 As said, the Doctor Diff booster and bracket Bendix Style Dual Diaphragm Booster for Mopars A distribution block suitable for four wheel drums and a dual pot master cylinder Mopar 1 Piece Distribution Block And a dual pot master cylinder for four wheel drums, '67 and later, several different styles. For example: 1967: More Information for RAYBESTOS MC36221 1975: More Information for CENTRIC 13063018 You will need to bend up new lines from the M/C to the distribution valve, and tweek your old lines from your old valve to the front and rear. Alternatively, Doctor Diff (and others) have custom pre-bent line kits. https://www.doctordiff.com/front-brake-line-selector.html Mopar Front to Rear Brake Line Selector for A/B/E Bodies
