moper
What a set of rhs flow ootb since there are none really doesn't matter since the op CLEARLY states he planned on buying IMM RHS heads. Making a comparison of the ede's to the imm is ABSOLUTELY valid as an OOTB comparison because the imm head does not come bare.
Running a hyd roller, you'll be upgrading springs or adding an inner. The parts that come on the ede's are not the same as the imm parts. You sure won't have spring interference issues if going roller rockers when using IMM rhs heads.
Slower cars overcome more weight easier, require less hp, than faster ones.
Some people don't like the chunk of aluminum look that the ede's have. I'm putting 24's on my car cause I like bling.. ukel: If you want that look, have at it.
I have 3 sets of ede heads. I'd have NONE if the RHS heads had been out when I bought them. The ONLY way I buy ede's is if I get a great deal on a set and then have them worked over to my liking so I don't have more in them than a set of RHS $.
Even with a good VJ, the ede's in stock port form WILL NOT make equal power on the same engine as a set of IMM rhs heads. Try it on a 425hp 360...
Here's one of my engine and I think it looks like dogcrap with ede heads.
Cracked - You are assuming "all other parts equal". In that particular instance you are correct - the RHS heads flow more at mid lift and as a result and depending on the cam choice can make more power with a smaller cam. My point is - the builder shouldn't BE using the same parts (namely pistons and camshafts) with these two head choices. I'm not debating whether they are good value or not - they are. But if a customer has the $$ for them, I'll go aluminum every time.
As far as the tailights comments -
You (and others) are also assuming that by "street driving" I mean street racing - as in drag racing. That is also totally incorrect an if you read my post I thought I made that clear. I'm referring to turns, and braking, and power in coming off a turn. You take 50lbs off the nose of any car at 1' above the center of gravity and that car will out brake, out turn, and out drive yours in everything but accelerating in a straight line. As you say - "simple fact".
Idaho - Like you noticed - lots of opinions on this subject...lol. The only one that matters is yours.
