Permits will be required. Also you have to follow a designated route to your destination.
Forgot to add, you will need flags, markers, lights and a cord long enough to reach the rear for lights, AND you will need wide load banners front and rear as well as amber warning lights. Not to mention some way of attaching mirrors so you can see down the sides of it. You may also have to purchase additional insurance as well.
Also it depends on what the state requires, you may also need a spotter vehicle front and rear to travel with you. You also can't be on the road from sundown to sunrise.
With those types of criteria, it might be advantageous to just hire someone with a mobile home toter to take it where you want it. There will be a lot of things to consider when doing this, IF you don't do it correctly DOT will have a field day with you!!!
I used to pull mobile homes and there is a lot to it other than just hooking on and going because it IS an oversize load.
