Will This Set of Ignition Points Fit/Work on early Abody?
dibbons
La Paz, B.C.S., Mexico
Back when I was studying Auto Tech at community college (circa 1973) I don't recall seeing a point set with the condenser and points as an integrated unit. I was sold these set as being compatible with our '65 Abodies. However, now that I take a second look at it, I wonder if there should be a nut on the threads of the condenser part? I also wonder if these points fit a Mopar distributor? Anyone ever use this type before who can answer my questions without guessing? Thank you.
GM had ones like that, but, I don't remember seeing any for Mopars. Easy way to find out....try to install it and see if it can be adjusted correctly.
