barty005
Any body ever fitted rear set of Wilwoods and instead of buying the rather $$ cables offered to sort the parking brake just modified what was on the car.
Having looked at it all and what is suggested at $130 I cant see why once the rear cables are removed from backing plate, you cant trim the cable slightly remove the return spring as it's not required purchase a set of clevis's for $40 shipped install and have another cable end fitted ( these cost $2).
Doing this also keeps a few more original parts on the car as well the suggested option seams to involve a few extra part being required that are not in the kit and a lot more work to get it all to function correctly, when what is already there works fine just seams to need a small adjustment.
Either way I'm going to give it a bash once clevis's arrive.
