beerboy
need some input here. should I start and run and drive my 73 duster 340 every now and then in the 4-5 months of winter storage, to get oil on the bearings? hearing a lot of different ideas on this, good- not good- to start , what is best? also when I go to run the car in the spring , should I put a bit of oil each cylinder before starting? change the oil before starting? or forget the above and let her sit? thanks for any info
