skep419
5.9 Magnum 4 speed afficionado
I have a denso alternator(internally regulated). Battery is in the trunk and solenoid is under glove box. Right now the red wire is getting twelve volts and the black wire has about 6 wires tapped into it (1.red-ignition switch 2.violet-horn relay 3.red/white stripe-fuse box 4.black-gauge cluster 5.black wire was cut went to fire wall plug 6.black/white stripe-headlight switch. What wires can be eliminated? I have a V gauge and don't care about the alt factory alt gauge. Below are the diagrams. The wires are the thickest (BOLD) wires in the diagrams.
http://www.mymopar.com/downloads/1969/69DartA.jpg
http://www.mymopar.com/downloads/1969/69DartB.jpg
