would/has anyone in here ever used a block with a tiny bit of epoxy in the lifter valley? this block was race prepped, completely ready to go with oiling mods, stroker clearance, clearance for solid rollers, bored, honed, align bored,decked, so on and so forth equating to almost $900. long story short, my father..who should have never touched it...decided to go at the lifter valley for just a weee bit more clearance on the lifters (when i was not around), and took the worst angle possible. he slivered a small crack where you can barely even see daylight. i patched it up with some super epoxy (aqua tech or something like that)...but i don't know if this little 1/16 x .25 sliver is enough to scrap the block over. i don't know if i can consciously use this block on anything other than a street engine. i'm told welding it up is grounds for a rebore another .010 over and re decking, and epoxy is the best way to go.
opinions? would you use it? what would you do? thanks guys.
