XV steering column boss HELP
Pablopaha
New Member
Australia
I'm in Australia and I bought an XV steering column, without a steering wheel boss, last year to fit to my 72 hardtop. I've finally got around to fitting the column to the car and have found that XV have closed shop.
Does anyone know if an aftermarket steering wheel boss will fir the XV column or do you need to use an XV boss??
Cheers
Steering coupler?
attachment.php
Rag joint?
Sorry, the steering boss is the adaptor that sits between the steering column and the steering wheel. It usually replaces the OEM concertina (tin can) that the steering wheel bolts to when you want to fit an after market steering wheel.
Oh that parts usually is sold by the company the wheel comes from. We have a aftermarket column in a 46 dodge truck. We used a Grant wheel and they just asked for some specs and sent out the correct "boss" as you call it
