ir3333
right click on each one and add to your photos...then you can blow them up to read them.
Are these articles something you could send me direct by chance? I'd like to read them but the photos are way to small.
Very hard. Eye strain
I'm on a phone....if ya right click them and save them on your computer you'll be able to read them.. this forum shrinks the hell out of them.. very good articles.
Uncle Tony says you need to weld the inside of the slot, instead of the outside, because of "things". Also you apparently, for best results, you need to do it with the distributor in the car. I saw the video, it can't be wrong.
I'm on a phone....
Oh wow. Ok. Hey, I wasn't brought up with these things. Lol.and you cant read it? i can download it to my phone and blow it up..
I tried this am. I'll try againand you cant read it? i can download it to my phone and blow it up..
You need to watch the video. He gives a reason, it may even be true.
I like it, I bought one of those limiter plates. ended up stealing it out of the distributor it was in and using it as a gauge to modify the slot on my slant distributor.
I'm going toDid it work for you? I can email it to you if ya want.
Makes complete sense. Fo' once evn i cain see that! Probably something to do with the rotation of the distributor having to only hit six plug wires instead of eight maybe but then again what the hell do I know?Be careful there, because the slant six distributor is different somehow then the V8. I have the limiter plate in mine and had to put it all the way down to the lowest slot and it advances more than the slot is supposed to allow. It's not the same.
I'm going to
Wow Man! I wonder if it has something to do with whoever programmed the thing. they cut their things out of stainless steel.I really don't know what the difference is, but I'm not the only one that's seen it. Several people have emailed Don Gould including me asking him to either offer one slant 6 specific, or at least offer a plate that has more limiting ability. He flat refused me. In no uncertain terms. That's why I welded my own governor plate.
