you know your stupid when
Discussion in 'Small Block Mopar Engine' started by Snake, Jun 9, 2010.
  1. Snake
    Snake Mopar Nut
    9,291
    135
    May 22, 2006
    Belleville Canada
    View My Photos
    Local Time:
    10:40 AM
    Ok I take my half blind wife cindy to Kingston Ontario today about 50 miles away to an appointment for an eye check up.On the way there in our old 99 sunfire when the temp goes a tab past what i like to see no over heating yet.So we get there ok,after 2 hours I check the coolant well maybe add a little water,now here is were i am STUPID,I forgot to put the cap back on the plastic tank drove home no problims untill I pull off the highway than starts to steem up and heat up to the point it reads in the red.Got it home let it cool a bit went around the block dam back to reading in the red again.Ok off to a shop I trust it had it toad there, cools down service manager say its fine.I am waiting for my buddy to call tonight to tell me what he did or not did.I dont understand why it would heat up and now be fine.Sorry this is long but I feel very STUPID right now.#-o
  2. moper
    moper FABO Gold Member FABO Gold Member
    14,287
    600
    Dec 27, 2004
    eastern CT
    Local Time:
    4:40 PM
    I've doen that on my neon... twice. You're fine...
  3. MtNemoMopar
    MtNemoMopar In the doghouse
    3,072
    40
    May 22, 2004
    Mt Nemo, Ontario
    View My Photos
    Local Time:
    4:40 PM
    Those caps are garbage. I opened my daughters up once to check the coolant level, and could never get it to seal again. I just bought a new cap, and no more worriessss.
  4. Snake
    Snake Mopar Nut
    9,291
    135
    May 22, 2006
    Belleville Canada
    View My Photos
    Local Time:
    10:40 AM
    Ok but why would it heat up like that and than be fine.I havent got to the shop to get it yet.Could it be it lost all its pressure so the boiling point went up.
  5. Mad Dart
    Mad Dart Nothing to see Here!
    8,527
    79
    Sep 24, 2008
    Murrieta California
    Local Time:
    8:40 AM
    Sucking Air in the system? Just a thought...
  6. dodge freak
    dodge freak Well-Known Member
    3,973
    19
    Nov 5, 2006
    Too close to Detroit, lol
    Local Time:
    10:40 AM
    You better hope its in fact just fine--no damage done. Maybe-maybe not. I say drive it for a few days and if no problems--like losing coolant cause the head or intake gasket is seeping-- then celebrate. These newer motors can not be abused as much.
    From now on when removing something like a rad cap-place it where you can easily see it. Better yet where you can not miss it--like on your drivers seat-if you sat on it you would know it.--ha ha.
    Good chance everything be ok but I seen how problems can grow.
  7. Snake
    Snake Mopar Nut
    9,291
    135
    May 22, 2006
    Belleville Canada
    View My Photos
    Local Time:
    10:40 AM
    You got that right next time my smart hat will be on.I know more tomorrow .Thanksssss
  8. moper
    14,287
    600
    Dec 27, 2004
    eastern CT
    Local Time:
    4:40 PM
    Mine's overheated to the point it pings at idle and dies... Twice. Plus the two "leaving the radiator cap lose or off" deals. And this is the Neon which is prone to issues. (It had the updated gasket instaleld years ago). Fill it, bleed it, and it will more than liekly be fine. These new fangled engines are TOUGH to kill.
  9. memike
    memike Super Moderator Staff Member FABO Gold Member
    45,197
    2625
    Jan 8, 2006
    on the hill
    View My Photos
    Local Time:
    10:40 AM
    These new engines need to be burped like a baby when they loose fluid or when they want them flushed..
    Fill the radiator up and drive it up hill and down hill then side ways
    They use a tall tank that looks like a tall funnel to refill water in some of the new cars
    I have stayed at work during lunch to watch two cars getting filled while the tec's was at lunch. fill it then drive then fill again till the level stays topped off.
  10. redfastback
    redfastback Don't ask me... my garage is empty
    3,678
    5
    Apr 17, 2006
    california
    View My Photos
    Local Time:
    8:40 AM
    boiling point goes down if pressure goes down...each pound of pressure increases the boiling point 3-5 degrees. Have them pressure test the system, check the primary and auxiliary fans and relays.
  11. moper
    14,287
    600
    Dec 27, 2004
    eastern CT
    Local Time:
    4:40 PM
    My fans dont work and havent for years...lol. Hence the boiling over a few times. I start talking and foget it's running...lol. The worst part is for two years I've had an electric fan unit, plus wires an relay to set it up "stand alone" and I never take the time for it...lol.
  12. Cudafever
    Cudafever Well-Known Member
    2,231
    199
    Sep 27, 2009
    Local Time:
    9:40 AM
    Yup thats what i do.......only i lay it on the hood latch. when your done under the hood, you should look around before you slam it!!!
    After you brake a couple caps, you get better at looking around:cheers:
