Parting Out 73 Dart
Drg racr
East Central Indiana
Rating - 0%
0   0   0
I picked up a 1973 Dart and will take off what I need next week. After that, I'll part the rest. From what I see right now, it has a good v8 K member, 8-1/4 rear, 2 rallys, decent doors, decent trunk lid, tail lights, decent door panels (green), decent dash cluster, good glass and trim. I'll check more as I take off what I want.
It does have a good windshield, but shipping to Utah might cost more than its worth.
Column shift, I'll pull it and inspect the column.
am looking for the small angle, stainless, outside, roof gutter trim pieces that go at the top of the A post, both sides needed, about 2 inch long and angled. Richard.
I need the plastic cap on the top of the passenger side door panel. Also could use the interior panels that cover the sail panels and the front kick panel covers.
Fresh air vent is gone.
Column is out, but I'm not sure if its good. Theres a rubber seal and a ring handing at the bottom, and the output shaft slops around a bit
Do yo have the metal clips that hold the inside side trim, this is between the rear sail panels and the front - looking for 3 of them
Car went for scrap. I pulled as many good pieces as I could find.
Pulled both doors, good shape, no major dents, little scale at the seams but no rust-thru as far as I can see.
Pulled the trunk lid, same as the doors, little scale on the seams.
Inner and outer heater box, non-A/C.
Tail lights, not the greatest but good for a drive, no cracks in the red plastic. Chrome is pitted some.
Drip rail chrome, all but the small angled pieces.
Do you have this piece for the drivers side? Top of quarter panel where it meets roof and rear filler panel under rear window.
