I'm replacing my under-dash wiring harness...
Pulled the dash and gauge cluster out of the Barracuda and found this cut wire on the back....is it safe to assume it's just a ground? What is the rusted out nuts that say "RED" under it?
Quite a bit of rust on the nuts holding it as well.....
I'm going to replace all the bulbs while I'm in there - any easy way to test them before I reinstall?
Anything else I should do or check while I have it out ?????
Thanks in advance!
Jeff
Thanks in advance!
Jeff
