GY3 WEDGE
Anybody on this site that have that card in the car documentation ? I wonder if that card give option codes, anybody that can decode that card I know it s with the car vin & colour is correct .
Stellantis historical can provide 67 and older photos of IBM cards
No, there are multiple different stories, warehouse fires etc. They just don't have them.Did they stop using the cards in 67 or something?
I see the black bucket seat code. But that's just a guess on my part.
Thank you very much for taking the time to decode, was hopping it would give option on the card as I have not found build sheet yet car coming apart this week might get lucky!Probably cant read this but here it goes
The Card basically decodes to the text printed on the top line. The characters "-&0987654321" "&-0987654321" Probably is some sort of control or code that the computer reads that means something to the computer.
the xy1 ,xy2, xy3 columns (I noted them XX1, XX2 and XX3) is probably that same type of thing.
the leading column 1 with xy0 ( noted as ??) probably means this is the start of a record
all in all he card is neat but is not super helpful.
Not sure what the Y3 is after the GY3G?
there is a possibility i messed up a row or column it is a bit of a challenge to keep it all straight
I n us L6X9 is bucket seat for Duster model but maybe demon is M6X9 not sure on Demon just to clarifyL6X9 is the black bench seat code. M6X9 is the bucket seats code.
There is way too much information on the broadcast sheet to put on the card.The IBM card should have all of the info that's on the build sheet, as it's the computer version.
Plus it has more info about sales and routing, etc.
The IBM card the OP has is a quality card NOT a build cardThe IBM card should have all of the info that's on the build sheet, as it's the computer version.
I have one that simply decodes to LOCATOR, it does have the basic info just no options.The IBM card the OP has is a quality card NOT a build card
If you have looked at a IBM car with the option codes you will see there is no place for all the items on the Broadcast Sheet.My understanding is the IBM build card came first, then the broadcast sheet and fender tag.
IBM card has everything a broadcast sheet has, and more, except for part numbers listed at the bottom under the two BUILD CODES sections, such as the Torsion Bar #s.
The fender tag cannot fit everything from the IBM buildcard, or the broadcast sheet, for example my car has two items in column 57 of the IBM buildcard (574 & 579), T on the fender tag, the T gets the 4.
The Quality Card is set up the same as the IBM buildcard, so this might help.
