Right, all but the '67 440 HP heads that are closed chamber, have a low SSR. MOPARMAGA is correct in that the 906 has every bit as high a SSR as any of the stk. SBC iron, actually for the port, a bit too high. The comment was about said SSR, but even tho' the flow numbers suffer some, the early closed chambers will run on a 383 with great results.
The common; long ports that not only don't open on center, they don't even seat on center, with plugs as far to one side of the chamber as almost possible excepting the slightly better double-hump era, which actually double-squish with the right pistons, so.....chamber/bore shrouding & long flame travel in stock form, with valve angle nod going slightly to the BBM. Head bolt placement nearly the same, but even tho' the BBM has a lot more space/lateral angle, you're at the mercy of the castings which can be awful right where they should shine.
