need left and right 400 BB engine mounts for D-150
66plyValiant
windsor NS
Rating - 0%
0   0   0
I'm looking for a set of big block engine mounts (steel mounts) for a 1972-1980 dodge D-150 thats 2wd I believe 4wd is different. My engine is a 400, not sure if 383 and 440 is the same
please PM me if you have a set
I looked into this when I had a Ramcharger that I wanted to swap a spare 440 into. The mounts are the same from 361-440, but different by body style. I know that vans are different, too. Watch which ones you get. Good luck.
Mike
I think Schumacher has these.
there very expensive fro schumacher, and they made them from factory so there are a few still kicking around. recieved a PM about a set but no reply back yet I guess I will have to wait and see
Have a 78 set if you havn't found some
