Any clue on E.Q head flow?(1.92 valve?)
Abodybomber
Breaking street machines , since 1983.....:)
Legendary Member
Arroyo grande ca
Just curious,on 1.92 EQ Magnum head air flow numbers,can't seem to find it in search.Any help,would be helpful,thank you.
If I remember correctly, Hughes list exactly what EQ shows on their site:
http://www.aamidwest.com/enginequest/eq-cylinder-heads/flo/
EQ CYLINDER HEADS: FLOW NUMBERS
EQ strictly by the numbers. How our heads stack up.
Need to know how our numbers compare against the competition? EQ provides you with the following extensive list of cylinder head flow numbers to help you decide.
CH318A
Chrysler 5.2L / 5.9L Magnum
Intake
Lift CFM
0.1 68.20
0.2 124.10
0.3 179.60
0.4 213.80
0.5 227.00
0.6 233.10
Exhaust
Lift CFM
0.1 57.20
0.2 114.10
0.3 155.30
0.4 180.0
0.5 187.30
0.6 188.70
Go buy the back issue of Mopar Action where they flow tested all the heads, back to back, and the EQ's tromped all. Specs were posted there.
