Okay. I have a pair of exhaust manifolds in excellent condition. The part numbers are 2863549 and 2863553. I bought them for my '65 Barracuda but could not get them to fit. Instead they've been decorating my garage for a couple of years.
They have been Jet-Hot ceramic coated. There are no cracks of any kind. However, as you can see in the photo, there is a spot where I attempted to grind down a little make it clear the steering box. It's a tiny bit of material. The only problem is that part of the manifold is no longer coated. For a little extra I can have this re-coated. Or you could cheat and coat it yourself with a little of the POR-15 exhaust coating, which also works extremely well.
Asking $300 + actual shipping to your ZIP code from Portland, Oregon.
-marcus
-marcus
