[SOLD] A-body BBP Axles and backing plates
I have a 7 1/4 rear end with backing plates and drums.
Crap, totally forgot to add that..thanks.im assuming any bbp backing/drum plates will work.
If their backing plates off an A-body that's probably true. All other body styles had a different offset and will only work with axles of that offset. And axles are different for all rearends, 7-1/4, 8-1/4, or 8-3/4.
I've got drums, backing plates, hardware, e brake cables off an 8 3/4 from 70 Chrysler . PM me if interested
All bbp a body 8.75 axles are aftermarket made in two different offsets, be sure to get the right brakes for the axles or vise versa depending on what you get first.
I bought the Yukon axle from Mancini, it calls for B or C body backing plates from 8.75, I'm using C body 11in from a 69 fury. I would have used 10in, but try finding some in a scrap yard these days. lucky I found the C body stuff.
I have a set of Backing plates off a 8 3/4, I think its a 70 Dodge truck. If you are still after backing plates I can measure them for you....they might be 11 inches.No drums. Send a PM if interested.
Andrew/Kidd
Andrew/Kidd
I found some thanks.
