71 Demon Decal placement
mopar nut
Dearborn Heights Mi
Just finished my 71 Sublime Demon and need help as to where the "Demon & 340" decals were placed on the side as well as the rear sail panel. pictures would be helpful.
Have tried the search button and found info on a 72 but it apparently is different than a 71
Are you using the stripes or no? Also if would like for a reference i could take a couple pics of mine, mine may not be 100 % accurate but i researched it a lot before i installed them and where they are is the best i could figure
I am running the stripes and a picture would be helpful, I wasn't going to use the 340 part of the decal cause I'm running a 440 but a friend made me some 440 decals that look lik e the 340 and I want to put them in the correct spot
Awesome, do you need fender and tail panel placement?
I need one of the fenders, A friend had a picture of his 71 tail panel which hadn't been touched but like me he forgot to take one of the fenders before having them dipped. As you can see I am changing the look up a little.
vbpgimage.php
Ok cool ill try to take a pic and maybe include some rough measurements
See if this helps
