Fenderwell Hedders !!! Info Needed
SS Lancer
North Carolina
Hello Gents need advice with the following topic !!
Not sure which one to buy
Hedman # 75161 or Hooker # 5205
Fenderwell hedders
Money not the issue please give input etc .
I will have fitment adjustments I'm sure before they are finished because putting them in a Henry J with tilt front-end on a 505 inch Wedge with Victor heads .
#1 is exh port same as stock set up ? I know ports are raised but is that all and if I wanted to run mufflers on the Hedman units which have slip on collectors does anyone sale collectors with flanges with bolt holes so they could be similiar to Hooker style flanges
Thanks Chris
I run hooker competition fender wall headers on my demon,they're a tight fit and my have made a few field adjustments but they work well. I run a 500 cu in with rpm heads if that helps
