[WANTED] ............MEGA block.........
I have a mega block on the shelf. It is .030 over clean bore with a standard deck. For sale depending on the offer. motor was taken from this 72 duster there was a write up on this motor .Was a fresh motor. 69383valiant bought the alum. heads.Was a Customers car. Make an offer.
This was a running 500 cu in motor that was featured in mopar muscle. Built by Hughes . The cam was to big for the springs coil bound and broke the keepers.
Heads were sold to 69383valiant on this sight. They were redone by my son after sale. I believe the complete bottom end is on the pallet but not sure.
All I can see from the floor is the block with the mildon race pan on it. This motor was a running motor with head issues caused by hughes. We built a pump gas motor at the machine shop for the car.
This motor was purchaced by my son from the owner to build a procharged race motor. The pistons that were in this motor were heavy and had L rings which are no longer available. I believe the crank is up there but not sure. Bores have hash marks no ridge. I threw the cam away but all small parts are there.
I am selling the block the rest is a bonus. This is not a give away it is not eating anything on the shelf. Just don't see a future here for it. Hospital monday torn aorta. Only mentioned sale do to post. Cash only will not ship
I have a set of flat top Ross pistons that measure 4.522 for a .030 overbore. They have valve reliefs for the biggest valves that can be put in a B1 head, gas ports, .041 / .041 / thin oil with lots of room to the top ring from the crown and a good distance between the oil ring and the pin. Skirts coated. Came out of my 499. Might be good for that block.
And good luck with the aorta operation OMM.
