Leaf spring part #
RussDavis
Pittsfield, MA
Found these on my 65 Barracuda. Any body ID these.
I found the first one
P4120864 seems to be a left spring but it's on the right of the car. Can't find the other one.
Odd numbers on left, you would be looking for 863. They are 2800lb super stock springs. BOTH of mine are stamped with 80556PN. Also one is stamped with 863 part# and other 864# respectively. It's not uncommon for 2 of the same to be installed so the car sits level.
