Mopower71
Speed Demon
Anybody else have a hard time getting the cold engine to start and stay running until it's got some heat in it?
My 440 drives me nuts until it's hot. Pump pedal , start, stall, repeat, repeat, repeat. Get it going and have to keep pumping, then it will stall. Repeat again until it's finally got enough heat in the engine for it to stay running.
440
590 solid cam
11.5 -1 compression.
850 holley dp, with no choke
Anybody have any suggestions on how to make this process easier?
440
590 solid cam
