[FOR TRADE] 3.23 suregrip center section
75slant6
Russellville, ky
I have a 8 3/4 center section with 3.23 gears and a clutch type sure grip. Next time I’m down at Dad’s I’ll see what number the carrier is. I would like to trade for a 2.76 Suregrip. I’m located in Lewisburg, Ky.
I have a 8 3/4 center section with 3.23 gears and a clutch type sure grip................
Might be interested. So more info besides case would help.
What condition? Setup for stock axles with tapered bearings? What yoke?
I have a 276, in a 742 case, clutch SG with 7260 yoke, set for the greens. I haven't run it since acquired from a good standing member a while back.
I’ve never used the center section but last time I looked at it, the gears all looked good and it turned good. I’ll have to check n see what yoke is on it and see if the thrust buttons and everything is there.
