Small block yes so should I lock out dizzy and use fitech?SB? I suggest the MSD two wire or clone from Pace
Get the MSD, the clones (TSP) don't fit into the slot in the cam gear properly. You will have about 10 degrees of play and your timing will vary all over the place. Ask me how I know this.SB? I suggest the MSD two wire or clone from Pace
