Gordon Selbig
I pulled the steel panel that fits between the rear wheels. it had a piece of heavy craft paper on it.I was thinking I need to insulate it with foil that has a thermal break in it.The foil will radiate the heat back toward the floorboard.The foam sandwiched between the foils will be the thermal break. The mice don't like it. Has anybody done it this way?
