Not an a body, but my 98 1500 sport. 5.9 magnum and auto trans. The truck has 130k on it but runs good and is reliable as can be. Only problem that keeps bugging me is the transmission. When I take off from a stop, it goes ok if I baby it. If I go into the throttle a little more, it will slip. If I let off and get on it harder, it takes right off and quits slipping right away. Same thing when it shifts to second. If I'm very light on the throttle it shifts fine. If I'm trying to accelerate at less then 3/4 throttle,it will slip unless I let off, or give it more gas. Then it quits right away and takes off. It shifts smooth in all gears and 3rd and overdrive don't have the slipping problem. I changed fluid and filter about 5000 miles ago and adjusted kickdown cable. Didn't make any difference. Fluid has never been dark or smelled burnt and the pan was clean as a whistle. Any ideas on what this could be? Seems if the clutches were smoked it would of had some **** in the pan, or the fluid would have had the smell of death. Seems strange how getting into the throttle harder will make the slipping go away if it's in first, and if I hold it to the floor, it goes into second with no slipping at all. Not liking the idea of giving a transmission shop 2 grand if it's something I can fix myself. Thanks for any advice or suggestions guys. I always appreciate the help and glad to be part of a group of knowledgeable Mopar guys and gals
