Dusten
Active Member
I was going to replace my cam bearings since I will be replacing my cam and the engine is out. summit has "direct replacement" bearings and "high performance" bearings. I am going mostly for street performance with a little strip use once or twice a year. It is a 340, cam 292 .508, 10.7 compression, headers, stock x heads. Also is one brand better than another? I have clevite 77 P series crank bearings. Thanks for any insight or advise.
