meathead66
Mod Top
I have the Super stock springs 002 and 003 which I bought used and it’s been mini tubbed with the springs under the frame rails in their approx stock position. However the passenger side is 1.5”higher measuring from the bottom of the fender to the ground. In order to lower only that side can I either use a lowering block for only that side or re-position the front of the
spring to which hole? Don’t have the perches welded to the tubes yet so I figured now would be be that time.Dont really want to raise the left side as I kinda like the stance like that. Also haven’t set the pinion angle yet either. What say you all.
