5.2 - what rings?
Iron Oxide
Huntsville, AL
Hey Guys, I've got a '96 5.2 that I'm getting ready to build. The machine shop only had to hone the bores, so I'm using my OE pistons.
I've read on numerous threads that the Magnums used metric rings. I've noticed when searching for rings nearly all results are for 5/64th top and second rings which I'm assuming are for the non-Magnum LA's.
I measured all of the rings that came out of my pistons, and they're all .078" which is 5/64"... If they were 1.5mm, shouldn't they measure .059"?
Is there a std size moly faced ring PN you guys can recommend?
Thanks!
1.5mm 1.5mm 3mm if I remember right.
I dont have the part number though. Just did a rering on a 5.9 mag.
I appreciate it. I wonder how its possible this motor had 5/64 rings in it? I don't think the short block had been apart, but who knows.
